[GRASS-user] Re: r.out.gdal output size vs input size
LeeDaniel Lee.Daniel.1986 at gmail.com
Wed Jul 14 05:33:03 EDT 2010
Hi Espen,
r.out.gdal uses the current region settings. Is it possible that you've set
a high region resolution? Then your GeoTIFF is probably being resampled to a
higher resolution, causing the file to be a lot bigger.
Best,
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-out-gdal-output-size-vs-input-size-tp5291740p5291763.html
Sent from the Grass - Users mailing list archive at Nabble.com.
