[GRASS-user] Projection String I can not figure out
Markus Metz
markus.metz.giswork at googlemail.com
Wed Jul 14 09:51:29 EDT 2010
stephen sefick wrote:
> Is there a way to import and re-project into GRASS
> without having to use ogr2ogr first?
Reprojection using GRASS: import into a new location, reproject from
new location into target location with v.proj.
If the shapefile holds polygons, I would strongly advice against using
ogr2ogr for reprojection because (non-topological) ogr2ogr will likely
create small overlapping polygons and small gaps between originally
adjacent polygons.
Markus M
>>> GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943295]]
>>> This is the projection string from a shp file from the USGS national
>>> hydrography dataset. I would like to reproject this into another
>>> format, but I don't know exactly what proj4 definitions to use for
>>> this to make it work...
>> Maybe
>> g.proj georef=<path_to_.prj_file> -j
>> helps?
>> Markus M
> Stephen Sefick
> ____________________________________
> | Auburn University |
> | Department of Biological Sciences |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> |___________________________________|
> | sas0025 at auburn.edu |
> | http://www.auburn.edu/~sas0025 |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
