[GRASS-user] Arc Binary coverages- arggg!
    stephen sefick
    ssefick at gmail.com
    Wed Jul 14 10:36:12 EDT 2010
Thank you very much for all of your help.
On Wed, Jul 14, 2010 at 9:33 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Probably the did not send you the entire thing since Arc coverages
> have data in the info folder. Maybe if they export the coverage as an
> e00 file or as a shapefile it would be better.
> Daniel
> On Wed, Jul 14, 2010 at 11:01 AM, stephen sefick <ssefick at gmail.com> wrote:
>> They were sent to me by some folk I am working with.  I don't know how
>> they generated the coverages.
>> On Wed, Jul 14, 2010 at 8:59 AM, Mark Seibel <mseibel at gmail.com> wrote:
>>> How did you obtain the coverage?  They are typically distributed as
>>> e00 files, which when imported create a directory for the geometry and
>>> an info directory for the attributes.
>>> Mark
>>> On Wed, Jul 14, 2010 at 9:20 AM, stephen sefick <ssefick at gmail.com> wrote:
>>>> I don't have an info directory.  I tried using v.in.ogr to no avail.
>>>> So, I downloaded the nation hydrography dataset and now I am trying to
>>>> find out projection information.
>>>> thanks,
>>>> STephen
>>>> On Tue, Jul 13, 2010 at 8:10 AM, Mark Seibel <mseibel at gmail.com> wrote:
>>>>> Much to my delight, v.in.ogr reads the binary arc coverages.  I copied
>>>>> over the directory (which is the coverage name) and the info directory
>>>>> to a place on the Linux machine which has GRASS installed.  (not sure
>>>>> if the 'info' directory is needed, but it did preserve attributes).
>>>>> For the OGR datasource name, I pointed it to the "arc.adf" file, and
>>>>> it imported the coverage as a GRASS vector with points, lines and
>>>>> polygon features.  Attributes also preserved.
>>>>> Please let me know if you have any issues with this.  First time I
>>>>> tried this, and great to know it can read the binary coverages.
>>>>> Mark
>>>>> On Mon, Jul 12, 2010 at 8:02 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>>>>> That's what I figured.  Then I am fairly sure this is what you're
>>>>>> after, http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html.
>>>>>>  Arc Vector coverages are stored in 2 directories.  One for geometry
>>>>>> (the directory is the name of the coverage) and the database is
>>>>>> contained in an 'info' directory.  The examples below are not clear to
>>>>>> me how it addresses this, but it does state it will do it.  I could
>>>>>> try some testing tomorrow if not figured out by then.
>>>>>> # Arc Coverage
>>>>>> We import the Arcs and Label points, the module takes care to build areas:
>>>>>> v.in.ogr dsn=gemeinden layer=LAB,ARC type=centroid,boundary output=mymap
>>>>>> # E00 file (see also v.in.e00)
>>>>>> First we have to convert the E00 file to an Arc Coverage with
>>>>>> 'avcimport' (AVCE00 tools, use e00conv first in case that avcimport
>>>>>> fails):
>>>>>> avcimport e00file coverage
>>>>>> v.in.ogr dsn=coverage layer=LAB,ARC type=centroid,boundary output=mymap
>>>>>> All the best.
>>>>>> Mark
>>>>>> On Mon, Jul 12, 2010 at 7:47 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>>>>> Vector Coverages.
>>>>>>> On Mon, Jul 12, 2010 at 6:41 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>>>>>>> Are these vector coverages or raster datasets?
>>>>>>>> Mark
>>>>>>>> On Jul 12, 2010, at 6:08 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>>>>>>> I have a couple of files that are in this format...
>>>>>>>>> aat.adf  arx.adf     dbltic.adf  metadata.xml  prj.adf  txx.adf
>>>>>>>>> arc.adf  dblbnd.adf  log         par.adf       txt.adf
>>>>>>>>> they are arc binary data correct.  Is there anyway I can use these
>>>>>>>>> with GRASS or QGIS?
>>>>>>>>> Stephen Sefick
>>>>>>>>> ____________________________________
>>>>>>>>> | Auburn University                                   |
>>>>>>>>> | Department of Biological Sciences           |
>>>>>>>>> | 331 Funchess Hall                                  |
>>>>>>>>> | Auburn, Alabama                                   |
>>>>>>>>> | 36849                                                    |
>>>>>>>>> |___________________________________|
>>>>>>>>> | sas0025 at auburn.edu                             |
>>>>>>>>> | http://www.auburn.edu/~sas0025             |
>>>>>>>>> Let's not spend our time and resources thinking about things that are
>>>>>>>>> so little or so large that all they really do for us is puff us up and
>>>>>>>>> make us feel like gods.  We are mammals, and have not exhausted the
>>>>>>>>> annoying little problems of being mammals.
>>>>>>>>>                                -K. Mullis
>>>>>>>>> _______________________________________________
>>>>>>>>> grass-user mailing list
>>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>> Stephen Sefick
>>>>>>> | Auburn University                                   |
>>>>>>> | 331 Funchess Hall                                  |
>>>>>>> | Auburn, Alabama                                   |
>>>>>>> | 36849                                                    |
>>>>>>>                                 -K. Mullis
>>>> Stephen Sefick
>>>> | Auburn University                                   |
>>>> | 331 Funchess Hall                                  |
>>>> | Auburn, Alabama                                   |
>>>> | 36849                                                    |
>>>>                                 -K. Mullis
>> Stephen Sefick
>> | Auburn University                                   |
>> | 331 Funchess Hall                                  |
>> | Auburn, Alabama                                   |
>> | 36849                                                    |
>>                                 -K. Mullis
Stephen Sefick
| Auburn University                                   |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
                                -K. Mullis
