[GRASS-user] global radiation calculated with r.sun seems to
be very high
Frank Reekers
f.reekers at fh-osnabrueck.de
Fri Jul 16 15:23:16 EDT 2010
I think, that's not a back-of-the-envelope calculation, it is more a
good way to verify things and not believe everything...
But, back to my problem: Yes, you are right. PVGIS values are real-sky
values => http://re.jrc.ec.europa.eu/pvgis/solres/solrespvgis.htm.
So, if I build the ratio of real-sky to clear-sky (PVGIS/r.sun) I get
for february 0.5628, that means ~56% of the solar radiation doesn't
reach the earth, right?
Let's do the same calculation for a summer day. If I take mid of july
(day=196) using r.sun (with lin=4.4) I get a global radiation of 7651
KWh/m² per day, PVGIS shows an average value of 4730 KWh/m² per day for
july. The ratio for july (PVGIS/r.sun) is 0.6182....hmm, in summer more
radiation losses in percent as in winter, could this be right?
> Hamish schrieb:
>> ok, this is probably the worst back of the envelope calc you'll ever
>> come
>> across, but it gives me an idea, maybe the PVGIS value takes average
>> cloud
>> cover into account while r.sun (by default) does not? I don't know if
>> Germany's winter is anything like England's, if it is this might explain
>> the difference... ?
>> lat = 52.267
>> day_of_year = 45
>> % lat_tropic: 23 + 26/60 + 16/3600 = 23.438
>> % so crudely:
>> [0 -23.438
>> 45 -11.719
>> 90 0
>> 180 +23.438 ]
>> sun_angle_noon = 52.267 + 11.719 = 63.986
>> solar_constant = 1367 % W/m^2
>> peak_rad = cos(sun_angle_noon * pi/180) * solar_constant
>> mean_rad = peak_rad * 2/pi % more crudeness
>> sunlight_hrs = 7 % rough guess
>> sunlight_hrs * mean_rad
>> = 2671.8 Wh/m^2 /day [Clear sky]
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100716/56caab21/f_reekers.vcf
