[GRASS-user] Re: problem with v.rast.stats
Helmut Kudrnovsky hellik at web.de
Sun Jul 18 09:02:08 EDT 2010
hi,
I've also tested WinGRASS-6.4.SVN-r42815-1-Setup.exe on my WinVista32-box
with the manpage-example from spearfish (also dbf).
v.rast.stats, v.info, v.db.select, v.univar are working normally (all modules finished in about 1 minute).
but I've seen that, during v.rast.stats is processing, zoom in and out in the mapdisplay, v.rast.stats
can't finish correctly (message:  ...elevation.dem can't be closed...) and in the mapdisplay
vector- and raster-maps are displayed in a mess.
maybe beacause of a temporal mask in the process?
Helmut
-----Ursprüngliche Nachricht-----
Von: Hamish
Gesendet: 18.07.2010 14:14:40
An: grass-user at lists.osgeo.org,Helmut Kudrnovsky
Betreff: Re: problem with v.rast.stats
Helmut:
> tested with the latest nightly WinGrass64-build:
> v.rast.stats vector=myfire at user1 raster=elevation at PERMANENT colprefix=te
> v.rast.stats works normally.
I just tried with 6.4 nightly build r42815 on XP + the example in
the man page+dbf, and it seemed to freeze during a call to v.info
with cpu use at 0% and lots of free RAM.
^C did not seem to work from the msys rxvt terminal.. had to "X"
the term window.
now added -x to the shebang in the script (not sure if that does
anything on wingrass), set DEBUG=5, and used --verbose. It's still
running after ~10 minutes, lots and lots of debug messages to get
through...  will try DEBUG=3 or less next time.
Hamish
___________________________________________________________
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
