[GRASS-user] DBMI-DBF driver error
Sandile Gumede akasandile at gmail.com
Mon Jul 19 02:55:26 EDT 2010
Hi Markus
Here is the output:
+ v.db.connect map=catchments -g fs=;
+ grep -w 1
+ TABLE=catchments
+ [ -z catchments ]
+ BASECOLS=n min max range mean stddev variance cf_var sum
+ [ 0 -eq 1 ]
+ EXTRACOLS=
+ unset ADDCOLS
+ [ 1 -eq 1 ]
+ echo prec_n
+ cut -b1-10
+ CURRCOLUMN=prec_n
+ sed s+$+|+g
+ v.info -c catchments --quiet
+ grep |prec_n| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
+ [ -n  ]
+ [ n = n ]
+ COLTYPE=INTEGER
+ ADDCOLS= prec_n INTEGER
+ [ 1 -eq 1 ]
+ echo prec_min
+ cut -b1-10
+ CURRCOLUMN=prec_min
+ sed s+$+|+g
+ grep |prec_min| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
+ [ -n  prec_n INTEGER ]
+ ADDCOLS= prec_n INTEGER,
+ [ min = n ]
+ COLTYPE=DOUBLE PRECISION
+ ADDCOLS= prec_n INTEGER, prec_min DOUBLE PRECISION
+ [ 1 -eq 1 ]
+ echo prec_max
+ cut -b1-10
+ CURRCOLUMN=prec_max
+ grep |prec_max| --quiet
+ sed s+$+|+g
+ sed s+^+|+g
+ [ 1 -eq 0 ]
+ [ -n  prec_n INTEGER, prec_min DOUBLE PRECISION ]
+ ADDCOLS= prec_n INTEGER, prec_min DOUBLE PRECISION,
+ [ max = n ]
+ ADDCOLS= prec_n INTEGER, prec_min DOUBLE PRECISION, prec_max DOUBLE
PRECISION
+ [ 1 -eq 1 ]
+ echo prec_range
+ cut -b1-10
+ CURRCOLUMN=prec_range
+ sed s+$+|+g
+ grep |prec_range| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
+ [ -n  prec_n INTEGER, prec_min DOUBLE PRECISION, prec_max DOUBLE PRECISION
PRECISION,
+ [ range = n ]
PRECISION, prec_range DOUBLE PRECISION
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_mean
+ CURRCOLUMN=prec_mean
+ sed s+$+|+g
+ grep |prec_mean| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
PRECISION, prec_range DOUBLE PRECISION ]
PRECISION, prec_range DOUBLE PRECISION,
+ [ mean = n ]
PRECISION, prec_range DOUBLE PRECISION, prec_mean DOUBLE PRECISION
+ [ 1 -eq 1 ]
+ echo prec_stddev
+ cut -b1-10
+ CURRCOLUMN=prec_stdde
+ sed s+$+|+g
+ grep |prec_stdde| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
PRECISION, prec_range DOUBLE PRECISION, prec_mean DOUBLE PRECISION ]
PRECISION, prec_range DOUBLE PRECISION, prec_mean DOUBLE PRECISION,
+ [ stddev = n ]
prec_stdde DOUBLE PRECISION
+ [ 1 -eq 1 ]
+ echo prec_variance
+ cut -b1-10
+ CURRCOLUMN=prec_varia
+ sed s+$+|+g
+ grep |prec_varia| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
prec_stdde DOUBLE PRECISION ]
prec_stdde DOUBLE PRECISION,
+ [ variance = n ]
prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION
+ [ 1 -eq 1 ]
+ echo prec_cf_var
+ cut -b1-10
+ CURRCOLUMN=prec_cf_va
+ sed s+$+|+g
+ grep |prec_cf_va| --quiet
+ sed s+^+|+g
+ [ 1 -eq 0 ]
prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION ]
prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION,
+ [ cf_var = n ]
prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION, prec_cf_va DOUBLE
PRECISION
+ [ 1 -eq 1 ]
+ echo prec_sum
+ cut -b1-10
+ CURRCOLUMN=prec_sum
+ grep |prec_sum| --quiet
+ sed s+^+|+g
+ sed s+$+|+g
+ [ 1 -eq 0 ]
PRECISION ]
PRECISION,
+ [ sum = n ]
PRECISION, prec_sum DOUBLE PRECISION
+ g.message -v Adding columns < prec_n INTEGER, prec_min DOUBLE PRECISION,
prec_max DOUBLE PRECISION, prec_range DOUBLE PRECISION, prec_mean DOUBLE
PRECISION, prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION,
prec_cf_va DOUBLE PRECISION, prec_sum DOUBLE PRECISION>
+ v.db.addcol map=catchments columns= prec_n INTEGER, prec_min DOUBLE
PRECISION, prec_max DOUBLE PRECISION, prec_range DOUBLE PRECISION, prec_mean
DOUBLE PRECISION, prec_stdde DOUBLE PRECISION, prec_varia DOUBLE PRECISION,
+ [ 0 -ne 0 ]
+ g.message -v Processing data ...
+ CURRNUM=1
+ rm -f /home/tgumede1/grassdata/Cape_
Town/Original/SRTMDEM/PERMANENT/.tmp/tgumede1-desktop/23218.0.sql
+ [ 0 -eq 1 ]
+ EXTSTAT=
+ cat
/home/tgumede1/grassdata/Cape_Town/Original/SRTMDEM/PERMANENT/.tmp/tgumede1-desktop/23218.0.cats
+ g.message -v message=Processing category 262 (1/4)
+ g.remove MASK --quiet
+ GRASS_VERBOSE=0 r.mapcalc MASK=if(catchments_23218.0 == 262, 1, null())
+ unset n min max range mean stddev variance cf_var sum
+ r.univar -g map=trmm percentile=90
+ sed s+nan+NULL+g
+ eval n=0 null_cells=12 min=-NULL max=-NULL range=-NULL mean=-NULL
mean_of_abs=-NULL stddev=-NULL variance=-NULL coeff_var=-NULL sum=0
+ n=0 null_cells=12 min=-NULL max=-NULL range=-NULL mean=-NULL
+ cf_var=-NULL
+ [ 0 -eq 1 ]
+ eval value=${n}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_n
+ cut -b1-10
+ colname=prec_n
+ echo UPDATE catchments SET prec_n=0 WHERE cat=262;
+ eval value=${min}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_min
+ cut -b1-10
+ colname=prec_min
+ echo UPDATE catchments SET prec_min=-NULL WHERE cat=262;
+ eval value=${max}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_max
+ cut -b1-10
+ colname=prec_max
+ echo UPDATE catchments SET prec_max=-NULL WHERE cat=262;
+ eval value=${range}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_range
+ cut -b1-10
+ colname=prec_range
+ echo UPDATE catchments SET prec_range=-NULL WHERE cat=262;
+ eval value=${mean}
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_mean
+ colname=prec_mean
+ echo UPDATE catchments SET prec_mean=-NULL WHERE cat=262;
+ eval value=${stddev}
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_stddev
+ colname=prec_stdde
+ echo UPDATE catchments SET prec_stdde=-NULL WHERE cat=262;
+ eval value=${variance}
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ colname=prec_varia
+ echo UPDATE catchments SET prec_varia=-NULL WHERE cat=262;
+ eval value=${cf_var}
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_cf_var
+ colname=prec_cf_va
+ echo UPDATE catchments SET prec_cf_va=-NULL WHERE cat=262;
+ eval value=${sum}
+ value=0
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_sum
+ colname=prec_sum
+ echo UPDATE catchments SET prec_sum=0 WHERE cat=262;
+ expr 1 + 1
+ CURRNUM=2
+ g.message -v message=Processing category 549 (2/4)
+ GRASS_VERBOSE=0 r.mapcalc MASK=if(catchments_23218.0 == 549, 1, null())
+ sed s+nan+NULL+g
+ cf_var=-NULL
+ [ 0 -eq 1 ]
+ eval value=${n}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_n
+ cut -b1-10
+ colname=prec_n
+ echo UPDATE catchments SET prec_n=0 WHERE cat=549;
+ eval value=${min}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_min
+ cut -b1-10
+ colname=prec_min
+ echo UPDATE catchments SET prec_min=-NULL WHERE cat=549;
+ eval value=${max}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_max
+ cut -b1-10
+ colname=prec_max
+ echo UPDATE catchments SET prec_max=-NULL WHERE cat=549;
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_range
+ echo UPDATE catchments SET prec_range=-NULL WHERE cat=549;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_mean
+ cut -b1-10
+ colname=prec_mean
+ echo UPDATE catchments SET prec_mean=-NULL WHERE cat=549;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_stddev
+ cut -b1-10
+ echo UPDATE catchments SET prec_stdde=-NULL WHERE cat=549;
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo UPDATE catchments SET prec_varia=-NULL WHERE cat=549;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_cf_var
+ cut -b1-10
+ echo UPDATE catchments SET prec_cf_va=-NULL WHERE cat=549;
+ eval value=${sum}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_sum
+ cut -b1-10
+ colname=prec_sum
+ echo UPDATE catchments SET prec_sum=0 WHERE cat=549;
+ expr 2 + 1
+ CURRNUM=3
+ g.message -v message=Processing category 724 (3/4)
+ GRASS_VERBOSE=0 r.mapcalc MASK=if(catchments_23218.0 == 724, 1, null())
+ sed s+nan+NULL+g
+ cf_var=-NULL
+ [ 0 -eq 1 ]
+ eval value=${n}
+ value=0
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo prec_n
+ colname=prec_n
+ echo UPDATE catchments SET prec_n=0 WHERE cat=724;
+ eval value=${min}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_min
+ cut -b1-10
+ colname=prec_min
+ echo UPDATE catchments SET prec_min=-NULL WHERE cat=724;
+ eval value=${max}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_max
+ cut -b1-10
+ colname=prec_max
+ echo UPDATE catchments SET prec_max=-NULL WHERE cat=724;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_range
+ cut -b1-10
+ echo UPDATE catchments SET prec_range=-NULL WHERE cat=724;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_mean
+ cut -b1-10
+ colname=prec_mean
+ echo UPDATE catchments SET prec_mean=-NULL WHERE cat=724;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_stddev
+ cut -b1-10
+ echo UPDATE catchments SET prec_stdde=-NULL WHERE cat=724;
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo UPDATE catchments SET prec_varia=-NULL WHERE cat=724;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_cf_var
+ cut -b1-10
+ echo UPDATE catchments SET prec_cf_va=-NULL WHERE cat=724;
+ eval value=${sum}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_sum
+ cut -b1-10
+ colname=prec_sum
+ echo UPDATE catchments SET prec_sum=0 WHERE cat=724;
+ expr 3 + 1
+ CURRNUM=4
+ g.message -v message=Processing category 733 (4/4)
+ GRASS_VERBOSE=0 r.mapcalc MASK=if(catchments_23218.0 == 733, 1, null())
+ sed s+nan+NULL+g
+ cf_var=-NULL
+ [ 0 -eq 1 ]
+ eval value=${n}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_n
+ cut -b1-10
+ colname=prec_n
+ echo UPDATE catchments SET prec_n=0 WHERE cat=733;
+ eval value=${min}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_min
+ cut -b1-10
+ colname=prec_min
+ echo UPDATE catchments SET prec_min=-NULL WHERE cat=733;
+ eval value=${max}
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_max
+ cut -b1-10
+ colname=prec_max
+ echo UPDATE catchments SET prec_max=-NULL WHERE cat=733;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_range
+ cut -b1-10
+ echo UPDATE catchments SET prec_range=-NULL WHERE cat=733;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_mean
+ cut -b1-10
+ colname=prec_mean
+ echo UPDATE catchments SET prec_mean=-NULL WHERE cat=733;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_stddev
+ cut -b1-10
+ echo UPDATE catchments SET prec_stdde=-NULL WHERE cat=733;
+ value=-NULL
+ [ 1 -eq 1 ]
+ cut -b1-10
+ echo UPDATE catchments SET prec_varia=-NULL WHERE cat=733;
+ value=-NULL
+ [ 1 -eq 1 ]
+ echo prec_cf_var
+ cut -b1-10
+ echo UPDATE catchments SET prec_cf_va=-NULL WHERE cat=733;
+ eval value=${sum}
+ value=0
+ [ 1 -eq 1 ]
+ echo prec_sum
+ cut -b1-10
+ colname=prec_sum
+ echo UPDATE catchments SET prec_sum=0 WHERE cat=733;
+ expr 4 + 1
+ CURRNUM=5
+ g.message -v Updating the database ...
+ db.execute
input=/home/tgumede1/grassdata/Cape_Town/Original/SRTMDEM/PERMANENT/.tmp/tgumede1-desktop/23218.0.sql
database=/home/tgumede1/grassdata/Cape_Town/Original/SRTMDEM/PERMANENT/dbf/
driver=dbf
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected NULL_VALUE processing 'NULL'
in statement:
Error in db_execute_immediate()
ERROR: Error while executing: 'UPDATE catchments SET prec_min=-NULL WHERE
       cat=262'
+ EXITCODE=1
+ cleanup
+ g.region region=23218.0
+ g.remove region=23218.0 --quiet
+ g.remove rast=catchments_23218.0 --quiet
+ [ 0 -eq 1 ]
+ rm -f
23218.0
+ [ 1 -eq 0 ]
+ exit 1
On Fri, Jul 16, 2010 at 10:12 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Jul 15, 2010 at 1:10 PM, Sandile Gumede <akasandile at gmail.com>
> wrote:
> >> I'm using GTOPO30 DEM data and TRMM (rainfall) data, I selected the data
> >> for the whole of africa but I'm getting an error when executing
> >> v.rast.stats.
> >> v.rast.stats vector=catchments raster=rainfall colprefix=precip
> >> WARNING: Area without centroid (may be OK for island)
> >> in statement:
> >> UPDATE catchments SET precip_cf_=-NULL WHERE cat=17
> >> ERROR: Error while executing: 'UPDATE catchments SET precip_cf_=-NULL
> >> WHERE
> >>        cat=17'
> There is a minus sign in front of NULL - never seen that and likely not
> SQL compliant (at least for the DBF driver which is just an enhanced table
> driver).
> Maybe it comes from here?
> [neteler at localhost v.rast.stats]$ grep NULL *
> v.rast.stats:   eval `r.univar -g $EXTSTAT map="$RASTER"
> percentile="$GIS_OPT_PERCENTILE" | sed 's+nan+NULL+g'`
> but AFAIK r.univar would not output -nan.
> Please edit your v.rast.stats script ("which v.rast.stats") to find
> the path if on Unix-like OS)
> and change the first line from
> #!/bin/sh
> to
> #!/bin/sh -x
> and run it again. From the detailed output you may see where this spurious
> comes in and tell us about it.
> Markus
Kind Regards
TS Gumede
CSIR, Meraka Institute
072 258 1650
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100719/e503066c/attachment-0001.html
