[GRASS-user] grass 7 quick question: how to display map in text mode
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Jul 22 04:17:04 EDT 2010
Hi
I need quick answer how can I show map in the text mode in grass7 (no d.mon)
It is because grass 7 wx gui has crashed after trying "save settings" in
wxgui preferences and wen I try to work GRASS finish his work with
following message:
I need any possibilities to see map results to track programing results
on GRASS 7 but unfortuntely I cannot help with that error. It seems
during "save settings" I blocked something but I cannot find what.
Below is the error message (grass 7 most recent svn, ubuntu 9.10 64 bits)
Thanks for answer
Jarek
Cleaning up temporary files...
Starting GRASS GIS...
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 37,
in <module>
import gui_modules.goutput
File
"/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_modules/goutput.py", line
37, in <module>
import preferences
File
"/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_modules/preferences.py",
line 902, in <module>
globalSettings = Settings()
File
line 590, in __init__
self.ReadSettingsFile()
File
line 661, in ReadSettingsFile
self.__ReadFile(filePath, settings)
File
line 703, in __ReadFile
self.Append(settings, group, key, subkey, value)
File
line 894, in Append
dict[group][key][subkey[0]][subkey[1]] = value
TypeError: 'tuple' object does not support item assignment
Error in GUI startup. If necessary, please report this error to the
GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
Unable to create temporary directory! Exiting.
