[GRASS-user] Re: Installing r.area
LeeDaniel
Lee.Daniel.1986 at gmail.com
Tue Jul 27 06:58:31 EDT 2010
Thanks for the replies! I've tried it out and here are my responses to the
suggestions:
@ Markus - Downloaded the script and put it in my scripts folder, made it
executable and made it assigned rights to myself. Just as a test I tried
opening it as a GUI and, lo and behold, it worked. However, it couldn't find
my add-on path, of course, when I tried to add r.area. So I went to the
terminal and entered:
export GRASS_ADDON_PATH?$GISBASE
g.extension r.area
Now things looked good. It did the following:
Fetching <r.area> from GRASS-Addons SVN (be patient)...
A r.area/main.c
A r.area/description.html
A r.area/Makefile
Checked out revision 42910.
- Great, got the files needed. Then it started compiling:
Compiling <r.area>...
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC6/bin.i686-pc-linux-gnu
mkdir -p
/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include/grass
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/lib
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/bin
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/etc
mkdir -p
/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/driver
mkdir -p
/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/driver/db
mkdir -p /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/fonts
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include
-O2 -DPACKAGE=\""grassmods"\"
-I/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c:19:23: fatal error: grass/gis.h: No such file or directory
compilation terminated.
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
- So it looks like it was able to make a bunch of directories. I checked,
they're there, new as of today. The entire directory of /usr/src/packages/
is new. However, GRASS wasn't able to compile. I checked for
/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include/grass/gis.h
since it seemed that it was looking for it and couldn't find it, and
discovered that the directory
is completely empty. Could that be the problem? I also tried using
sudo g.extension r.area
And got the usual error that I have to be in GRASS GIS to run the program. I
didn't try starting GRASS as a super user because I don't want to do
anything wrong and I also don't want it to install r.area only for super
users.
But that would be a nice way of loading add-ons, because it looks like I
wouldn't have to have the source code all on my hard drive. Any idea why
it's not working?
@ Micha - Tried running it with g.extension (see above); it didn't work, so
I tried to do the thing manually again. Entered
svn checkout https://svn.osgeo.org/grass/grass-addons/ grass-addons
to get the source codes. It worked and all the source codes were downloaded
to my home directory in the folder grass-addons. Then I navigated into the
directory
~/grass-addons/raster/r.area/
and entered the command
./configure
This is similar to last time; last time, I also had been inside the
directory when I tried the commands. But I thought hey, maybe I'd copied the
source codes wrong. Sadly, that doesn't seem to be the problem; just like
last time, I got the message
bash: ./configure: No such file or directory
I then tried it as super user. Same problem.
Any other ideas? Thanks a lot again for the help, everyone!
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Installing-r-area-tp5340139p5341684.html
Sent from the Grass - Users mailing list archive at Nabble.com.
