[GRASS-user] r.terraflow problem
Aleksey Naumov anaumov at gmail.com
Fri Jul 30 12:19:00 EDT 2010
Markus,
Thank you for your help. At least I figured out why r.terraflow would not
run at all - I had both stats.out and stats.out.old sitting on my hard disk
from some time before. As I understand now, r.terraflow creates a backup of
the runtime statistics file (by default, stats.out.old), and if this backup
file already exists, it simply refuses to remove it and bails out. Once I
removed the backup file r.terraflow started running.
The more interesting part is getting it to run to completion. It now stops
on a failed assertion (see below). Is this assertion related to the
temporary file size limitation you mentioned (for wingrass)? The thing is,
the temporary file does not get that large, only about 460 MB.
I thought that r.terraflow scales better to larger DEMs than r.watershed,
but I'll try r.watershed next.
As far as updating grass, this version (GRASS 6.4.0svn-7) is the latest
available via OSGeo4W. What other options do I have on WinXP (a Cygwin-based
install?)?
Thank you,
Aleksey
r.terraflow --overwrite --verbose elevation=dem at PERMANENT filled=tf_dem
direction=tf_fdir swatershed=tf_sink accumulation=tf_fac tci=tf_tci
STREAM_DIR=C:/Active_projects/tmp/tf
stats=C:/Active_projects/tmp/tf/stats.out
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
cell dem header compatible with region header
Elevation stored as FLOAT (4B)
Region size is 13000 x 9200
STREAM temporary files in C:/Active_projects/tmp/tf  (THESE
INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL
TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE
THESE FILES MANUALLY!)
file C:/Active_projects/tmp/tf/stats.out exists - renaming.
reading data from dem to stream
C:/Active_projects/tmp/tf/STREAM_a05968:
Assertion failed: nrows * ncols == str->stream_len(), file
grass2str.h, line 144
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
(Fri Jul 30 11:36:59 2010) Command finished (36
sec)
On Fri, Jul 30, 2010 at 2:23 AM, Markus Metz <
markus.metz.giswork at googlemail.com> wrote:
> Aleksey Naumov wrote:
> > Dear GRASS users,
> > I am trying to run r.terraflow in GRASS 6.4.0svn (GIS library revision:
> > 37101 (2009-05-10)) provided as part of the OSGeo4W bundle on WinXP. The
> > command prints some output, which looks normal, and then exits right away
> > without doing anything.
> > Here is the command and the output I get:
> > (Thu Jul 29 13:32:43
> > 2010)
> > stats.out: File exists
> This is 119.6 million cells, too large for wingrass, r.terraflow will
> most likely abort because the temporary files become too large (no
> large file support in wingrass). Try r.watershed instead.
> > file stats.out exists - renaming.
> Either manually delete the file stats.out first before running
> r.terraflow or, as suggested in the other reply, update grass.
> Markus M
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100730/d5130ec4/attachment.html
