[GRASS-user] Header information for Radiometric Correction
Markus Neteler neteler at osgeo.org
Tue Jun 1 05:25:35 EDT 2010
On Tue, Jun 1, 2010 at 10:35 AM, katrin eggert
<katrineggert1980 at gmail.com> wrote:
> Hi Markus and the rest of the people
>> The files in the indicated FTP directory are in a different
>> file format.
>> If you look at the .hdr files therein, you'll find the metadata easily.
>> They are in ASCII format, too.
> But the code refers to a *.met file right?
Right.
> So I was not "reading" the code wrong. So I just need to substitute *.met
> for  the new metadata?
Unfortunately not since the format (i.e. keywords) is different. You would need
to write a parsing script (shell, Python, etc).
Trick: open the file and read it :)
If you don't need to import many files, the manual composition of the
METASTRING variable will take you only few minutes at most.
>> > I need to import Landsat-7 image with all that information...
>> r.in.gdal should be able to import these data without problems.
> But r.in.gdal only imports the data not the metadata. Right?
Right.
>> > Even at NC_SPM landsat dataset, onlyu 2002 has Metadata information.
>> > 1987 doesn't have that.
>> Unfortunately various formats are used... But luckily most (all?) are
>> understood
>> by GDAL, so r.in.gdal should do the job. You can also obtain metadata
>> information
>> with
>>  gdalinfo filename
> And how can I automatically incorporate the metadata, specially from a
> external file, into imported file?
You can use r.support for that:
http://grass.osgeo.org/grass64/manuals/html64_user/r.support.html
r.support mapname history="$METASTRING"
Hope this helps,
Markus
http://gis.ambiente.fmach.it/
