Marcello wrote:
> However, I believe that if you have null cells in your
> raster and some of the random points happen to fall over
> them, you will have less valid points than you expect, so
> I would say that you should check the resultant database.
see http://grass.osgeo.org/wiki/GRASS_AddOns#v.random.cover
Hamish
