[GRASS-user] v.to.db
David Kindem
dkindem at gmail.com
Thu Jun 3 17:29:03 EDT 2010
Hello,
I am attempting to use v.to.db to insert values from a vector map
into a database table. At the terminal, I enter:
v.to.db map=crossings_1918_main option=coor col=east,north
I receive the following error:
DBMI-Postgres driver error:
Cannot select:
SELECT cat FROM crossings_main_1918,
ERROR: syntax error at end of input
LINE 1: SELECT cat FROM crossings_main_1918,
Updating database...
Segmentation fault
I am using 6.3, Lorenzo's binaries. Thanks in advance for any
thoughts or suggestions.
Dave
David Kindem
616.402.0864
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100603/f4083c4d/attachment.html
