[GRASS-user] Problem importing netCDF
Hanlie Pretorius
hanlie.pretorius at gmail.com
Fri Jun 4 06:13:57 EDT 2010
I'm using Win XP and GRASS 6.4RC6 to import a TRMM netCDF file using
the command:
r.in.gdal -o input =c:/data/3B42.000202.0.6.nc output=test band=precipitation
and am getting the error:
G_set_window(): Illegal latitude for North
gdalinfo for the file outputs:
Driver: netCDF/Network Common Data Format
Files: C:\data\3B42.000202.0.6.nc
C:\data\3B42.000202.0.6.nc.aux.xml
Size is 512, 512
Coordinate System is `'
Metadata:
NC_GLOBAL#Conventions=CF-1.0
Subdatasets:
SUBDATASET_1_NAME=NETCDF:"C:\data\3B42.000202.0.6.nc":precipitation
SUBDATASET_1_DESC=[400x1440] precipitation (32-bit floating-point)
SUBDATASET_2_NAME=NETCDF:"C:\data\3B42.000202.0.6.nc":relativeError
SUBDATASET_2_DESC=[400x1440] relativeError (32-bit floating-point)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
In Panoply (http://www.giss.nasa.gov/tools/panoply/), the information
for the file displays as:
netcdf file:/C:/data/3B42.000202.0.6.nc {
dimensions:
lat = 400;
lon = 1440;
variables:
float precipitation(lat=400, lon=1440);
:long_name = "precipitation";
:units = "mm hr-1";
:_FillValue = -9999.9f; // float
float relativeError(lat=400, lon=1440);
:long_name = "relativeError";
:units = "mm hr-1";
float lat(lat=400);
:standard_name = "latitude";
:units = "degrees_north";
:long_name = "latitude";
:_CoordinateAxisType = "Lat";
float lon(lon=1440);
:standard_name = "longitude";
:units = "degrees_east";
:long_name = "longitude";
:_CoordinateAxisType = "Lon";
:Conventions = "CF-1.0";
In the Panoply array display, the coordinates range from 49.875° to
-49.875° (lattitude) and -179.875° to +179.875° longitude. These are
coordinates for the centres of 0.25° grid cells.
I have set my region according to the documentation for the dataset to:
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 50N
south: 50S
west: 180W
east: 180E
nsres: 0:15
ewres: 0:15
rows: 400
cols: 1440
cells: 576000
Can someone perhaps spot my error?
Thanks
Hanlie
