[GRASS-user] v.rast.stats
Micha Silver
micha at arava.co.il
Tue Jun 8 12:23:53 EDT 2010
On 06/08/2010 05:24 PM, Sandile Gumede wrote:
> Hi,
> After running *v.rast.stats vect=catchments rast=rainfall
> colprefix=precip*, I ran *v.info <http://v.info> -c catchments* and I
> got 9 new columns:
> precip_min, precip_max, precip_ran, precip_mean, precip_std,
> precip_var, precip_cf_, precip_sum,.....,precip_per.
> How do I then be able to see how much rain has fallen in each
> catchment(polygon), and which direction is the water flowing?
v.db.select catchments column=precip_sum
If you display the stream network over the catchments, and use the
"display=shape,dir" option to d.vect then you'll see small arrows along
the streams indicating direction of flow.
> Kind Regards
> TS Gumede
> CSIR, Meraka Institute
> 072 258 1650
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100608/aebe2d70/attachment.html
