[GRASS-user] Re: r.grow.distance
Tue Jun 8 12:42:07 EDT 2010
fengel wrote:
> I am not familiar with c and also I didn't really get the idea of your fix.
> So there is something wrong with the total numbers of columns that
> r.grow.distance counts?
> Do you use your code as a kind of patch? I am using grass 6.4. I am also not
> familiar with patching things. Is there a way for me do use your fix?
The change has been committed to the 6.4 and 6.5 branches:
6.4:	http://trac.osgeo.org/grass/changeset/42412
6.5:	http://trac.osgeo.org/grass/changeset/42413
If you build from source, update to the latest SVN revision.
Or you can try the latest binary snapshot:
	http://grass.osgeo.org/grass64/binary/linux/snapshot/
