[GRASS-user] Re: Problems with v.what.rast
Rebecca Bennett rabennett at ymail.com
Wed Jun 9 04:40:57 EDT 2010
Hi Martin,
I tried the commandthat Micha suggested v.db.addcol map=Contour_points_cats at PERMANENT layer=1
columns="rast_value double precision" but this age the following error
v.db.addcol Contour_points_cats col=rast_value DOUBLE PRECISION
Sorry <DOUBLE> is not a valid option
Sorry <PRECISION> is not a valid option
So through the GUI I added a column to the attribute table which gave the command line out put
v.db.addcol map=Contour_points_cats at PERMANENT layer=1 {columns=rast_value double precision}
cheers!
To: Rebecca Bennett <rabennett at ymail.com>
Cc: Micha Silver <micha at arava.co.il>; grass-user at lists.osgeo.org
Sent: Wed, 9 June, 2010 9:37:14
Subject: Re: [GRASS-user] Re: Problems with v.what.rast
2010/6/9 Rebecca Bennett <rabennett at ymail.com>:
> I added a column v.db.addcol map=Contour_points_cats at PERMANENT layer=1
> {columns=rast_value double precision} (as my raster is a float), then ran
> with error
how did you get this command?
It should be
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100609/4f39b89a/attachment.html
