[GRASS-user] Re: Problems with v.what.rast
Rebecca Bennett
rabennett at ymail.com
Wed Jun 9 05:37:20 EDT 2010
Hi all,
I have deleted the column I added and tried all command line permutations of
v.db.addcol map=Contour_points_cats at PERMANENT layer=1 `col="rast_value DOUBLE PRECISION"`
v.db.addcol map=Contour_points_cats at PERMANENT layer=1 `columns="rast_value DOUBLE PRECISION"`
that have so far been given in this thread, again with quotes and without. Unfortunately it does not recognise this command, which I why I used the GUI
The GUI is tcltk on GRASS 6.4
Micha - I have checked the points are within the raster (they were created from a contour map of the raster). The region is consistent with both the raster and vector
Thanks!
To: Rebecca Bennett <rabennett at ymail.com>
Cc: Martin Landa <landa.martin at gmail.com>; grass-user at lists.osgeo.org
Sent: Wed, 9 June, 2010 10:12:28
Subject: Re: [GRASS-user] Re: Problems with v.what.rast
On 09/06/2010 11:40, Rebecca Bennett wrote:
>Hi Martin,
>>I tried the command that Micha suggested v.db.addcol
>>columns="rast_value double precision" but this age the following error
The quotes " " around the "rast_value DOUBLE PRECISION" are necessary.
Just to check can we see the output of
v.info -c Contour_points_cats
You might also check that the points are all within the raster region.
i.e.:
v.info -g Contour_points_cats
r.info -g Dartmoor1
g.region -p
v.db.addcol Contour_points_cats col=rast_value DOUBLE PRECISION
>>Sorry <DOUBLE> is not a valid option
>>Sorry <PRECISION> is not a valid option
>>So through the GUI I added a column to the attribute table which gave
>the command line out put
>{columns=rast_value double precision}
>>cheers!
>To: Rebecca Bennett
>Cc: Micha Silver
><micha at arava.co.il>; grass-user at lists.osgeo.org
>Sent: Wed, 9 June,
>2010 9:37:14
>Subject: Re:
>>Hi,
>>2010/6/9 Rebecca Bennett <rabennett at ymail.com>:
>>> I added a column v.db.addcol map=Contour_points_cats at PERMANENT
>layer=1
>>> {columns=rast_value double precision} (as my raster is a float),
>then ran
>>> with error
>>how did you get this command?
>>It should be
>>Martin
>>Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
>>This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100609/76f0d833/attachment.html
