[GRASS-user] Raster Import
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat Jun 12 16:53:00 EDT 2010
Hamish wrote:
> > If you are doing any numerical analysis on satellite images, etc,
> > this matters a lot and it's best to work with the raw bands, d.rgb,
> > etc. If you are just using it for visual use maybe it doesn't
> > matter.
Since it was not specifically mentioned: you can work with the created groups
(one groups for each imported image that holds the RGB channels). In fact some
imagery modules require the group(s).
Later you can export as a GeoTIFF all three-channels using the group(s).
Nikos
