[GRASS-user] Re: Compiling winGRASS with OSGEO4w- #2
Luisa Peña
luisapena1979 at gmail.com
Mon Jun 14 14:11:16 EDT 2010
After a few messages exchanged wirh Martin Landa (thanks Martin) I realized
that the problem is only with libgrass_display.dll that cannot be found. Is
the only problem. Has anyone ever had the same problem?
2010/6/14 Luisa Peña <luisapena1979 at gmail.com>
> About our prevous conversation here goes the compilation of Wingrass with
> OSGEO4w following a tip from Martin (not installing GRASS desktop from
> OSGEO4W)
> 1- I identified the extra modles that GRASS-desktop installation requires
> and installed only thse (except GRASS_locale and GRASS_gdal).
> 2- Run all thee steps from
> http://trac.osgeo.org/grass/wiki/CompileOnWindows#CompilingandInstallinguntil COMPILING AND INSTALLING GRASS (GRASS6.4.0) step 1.
> 3- Downloaded a Weekly snapshot from here
> http://grass.osgeo.org/grass64/source/snapshot/ (
> http://grass.osgeo.org/grass64/source/snapshot/grass-6.4.svn_src_snapshot_2010_06_12.tar.gz
> 4- Unpack gz and then tar to c:\osgeo4\usr\src
> 5- Inside C:\osgeo4w\usr\src\grass-6.4.svn_src_snapshot_2010_06_12 I
> runned:
> ./mswindows/osgeo4w/package.sh
> (currently, no folder named grass is in c:/osgeo4w/apps)
> - in my first (3) attempts I got errors in libraries that I installed in
> step 6 of the Wiki. I had to Reinstalled them.
> - log includes my log file from this process (at:
> http://pastebin.com/UdhLyv6f)
> - error.log is the error report. I got errors in almost all executable.
> QUESTION1:How can I add Python support to yes ? ( I will need Wxpython
> and use pythonscripts and probably pygdal)
> It created:
> a grass folder in /apps/
> - folder named bin in apps/grass with 2 files: grass64 and grass64.bat
> - a folder name grass-6.4.0svn with the following fodlerd: bin; bwidget;
> docs; driver, etc, fonts, include; lib; locale; scripts; tools.
> and it seems to be running but all the functions in error.log are not
> available.
> QUESTION2: What did I did that was wrong?
> 6- I went to
> C:\osgeo4w\usr\src\grass-6.4.svn_src_snapshot_2010_06_12\display and runned
> make -C d.histogram MODULE_TOPDIR=
> because d.histogram is one of the functions that is not available
> And I got:
> make: Entering directory
> `/c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/display/d.histogram'
> make: *** No rule to make target
> `/c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/lib/libgrass_display.dll',
> needed by
> `/c/osgeo4w/usr/src/grass-6.4.svn_src_snapshot_2010_06_12/dist.i686-pc-mingw32/bin/d.histogram.exe'.
> Stop.
> make: Leaving directory
> THank you
> Luisa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100614/0056b986/attachment.html
