[GRASS-user] Compiling GRAS on Windows- Log and error
Tue Jun 15 11:53:53 EDT 2010
Luisa Peña wrote:
> Hi Glynn. As you saw from previous messages, my problem now is with
> libgrass_display.dll.
> I saw a message that you sent to ML regarding this problem. Can it be
> related with prebinaries and MinGW packages version?
Maybe. Everything stems from the linker crashing while trying to build
libgrass_psdriver. This is required by libgrass_raster, which is
required by all d.* modules (and also by libgrass_display).
The psdriver library hasn't changed much recently, so it's more likely
to be an issue with the specific version of MSys' binutils.
