[GRASS-user] Re: Compiling winGRASS with OSGEO4w- #2
    Luisa Peña
    luisapena1979 at gmail.com
    Wed Jun 16 11:02:08 EDT 2010
Hi Helmut and List
Helmut I also installed that msysCORE update that is linked in Wiki. I only
didn't installed the Temp_bugfix since it was no package only a ticket :)
So I don't know what can I do to fix this. I'm running in Windows XP. Maybe
I was not suppose to install msysCORE-1.0.11-bin?
- Just one question: this missing dll, I have it a WinGRASSbinarySNAPSHOT
installation. can I use it?
- I needed to test with r.example... What MODULE_TOPDIR should I define to
compile r.example? (command: make -C r.example MODULE_TOPDIR= <DIR>)
If anyone has an idea of what package should I try to fix this error please
let me know
Thanks
Luisa
2010/6/16 Helmut Kudrnovsky <hellik at web.de>
> Hi Luisa,
> Von: "Luisa Peña"
> Gesendet: 16.06.2010 11:49:45
> An: Helmut Kudrnovsky ,GRASS user list
> Betreff: Re: Compiling winGRASS with OSGEO4w- #2
> >Hello Helmut
> >>I've done a completly new installation of my osgeo4w-installation on my
> WinVista32-box to get the latest osgeo4w-setup and followed the
>  wiki ([
> http://trac.osgeo.org/grass/wiki/CompileOnWindows#Pre-builtBinaries]) for
> installing
>  all dependencies, prebuilt libraries and utilities etc.
> >Did you installed the prebuilts and libraries that are linked in there or
> did you used updates?
> >And regarding: Temp bugfix (see [ here]),  what did you do with that?
> I've installed the linked ones.
> there were several bug-reports for WinVista/Win7 and the old msys,
> delivered by osgeo4 or linked in the wiki.
> because I prepare from time to time the WinGrass-installer for download
> from the grass.osgeo.org-site,
> I'm using the msys-files mentioned in the trac-ticket 118
> http://downloads.sourceforge.net/project/mingw/MSYS%20Base%20System/msys-1.0.11/msysCORE-1.0.11-bin.tar.gz
> >>I've choosen the way with TortoiseSVN to get a completly new svn-checkout
> at revision 42566
>  (see the wiki B) Graphical user interface based:
>  Alternatively, get TortoiseSVN, a plugin for Windows
>  Explorer, which can be used for managing the local source tree.) in
> C:\OSGeo4W\usr\src\grass64svn.
> >> I can't reproduce your error, Grass64 is compiling fine and I'm able to
> start Grass64 in
>  C:\OSGeo4W\apps\grass\bin (in the osgeo4w-msys-shell) by grass64 -wx.
> >Well, it compiled except those 3 functions...
> >>so I would suggest a completely new setup of the compiling-environment
> following the
>  wiki ([http://trac.osgeo.org/grass/wiki/CompileOnWindows]).
> >as you saw all my steps were the same... Exacly the same...
> And for instance, without changing anything, it goes from no compilation to
> compile with an error in a certain DLL.
> One question, I have that DLL from winGRASS installation. can I use that
> DLL in order to compile my code?
> HTH
>  Helmut
>  ___________________________________________________________
> [WEB.DE] DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
>  50,- Euro Geldprämie inklusive! [https://freundschaftswerbung.web.de]
> WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
> 50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100616/339d3fc8/attachment.html
