[GRASS-user] Re: how to get raster region corresponding to vector polygon region?
Marcello Gorini gorini at gmail.com
Thu Jun 17 19:17:52 EDT 2010
Kwas wrote:
> Hello,
> I have a raster map (dem) and I want to select a region of the raster
> corresponding to a polygon that is in a vector map.  What is the best
> way to do this?  It looks like r.in.poly might be along the lines of
> what I need but in that case I think I would need to generate the ascii
> poly file first but I'm wondering if there is a better way?  Seems
> like
> there should be a single command to do this.
> My vector map has 45 polygons with cat values 1..45,  so I would like
> to get a section from my raster map corresponding to one of the
> polygons specified by cat value.
> appreciate any help!
> thanks,
> ken
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hello Ken,
I am also new to GRASS, but I have been doing what you want quite a lot
these days. There is probably a better way to do that (and I would like to
"hear" it very much, specially if there is a single command to do this), but
for now, I think the code below does the job:
g.region vect=your_vector
v.extract input=your_vector output=selected_polygon type=area
where="cat=desired_cat"
v.to.rast input=selected_polygon output=polygon_rasterized use=val type=area
r.mask input=polygon_rasterized
Now, any processing that you do will be applied only in the region
corresponding to the selected polygon.
If you want to create a raster corresponding to the selected polygon, just
do:
r.mapcalc "new_raster=any_old_raster"
To take out the mask, just type:
r.mask -r
Hope this helps,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/how-to-get-raster-region-corresponding-to-vector-polygon-region-tp5192862p5193386.html
Sent from the Grass - Users mailing list archive at Nabble.com.
