[GRASS-user] problems with wxGUI in grass7.0
Paolo Craveri pcraveri at gmail.com
Fri Jun 18 17:23:53 EDT 2010
Hi to all
in GRASS 7.0.svn42585 (Ubuntu 10.04),  wxGui crashes when I load 1-2
vector  maps and set same properties, apparently without rules; I get
this message:
GRASS 7.0.svn (spearfish60):~ > The application 'python' lost its
connection to the display :0.0;
most likely the X server was shut down or you killed/destroyed the application.
Other times d.vect window appears but ... empty (no widgets inside).
Error is difficult to reproduce because (apparently) there are no
rules to get it.
No problems with grass 6.4. Perhaps a wrong compilation?
GRASS 7.0.svn (spearfish60):~ > g.version -b
GRASS 7.0.svn42585 (2010)
./configure  --with-cxx --with-blas --with-geos --with-lapack
--with-cairo --with-motif --with-gdal
--with-proj-includes=/usr/include --with-proj-libs=/usr/lib
--with-proj-share=/usr/share/proj --with-freetype=yes
--with-freetype-includes=/usr/include/freetype2 --with-postgres=no
--with-sqlite=yes --with-sqlite-includes=/usr/include
--with-sqlite-libs=/usr/lib --enable-largefile=yes
--with-tcltk-includes=/usr/include/tcl8.5
--with-opengl-libs=/usr/include/GL --with-readline
--with-python=/usr/bin/python2.6-config
--with-wxwidgets=/usr/bin/wx-config --with-includes=/usr/include
--with-libs=/usr/lib
Any suggestions?
Many thanks in advance.
Paolo C.
