[GRASS-user] Re: New modules in svn add-on: r.area and r.convergence
Marcello Gorini gorini at gmail.com
Sat Jun 19 19:36:08 EDT 2010
Jarek Jasiewicz wrote:
> Hi
> I added new two modules to svn add-on.
> r.area
> Simple module available in almost every raster processing GIS
> application. Calculates area size of clumped areas and ascribe these
> values to these areas. Also allow remove small areas with size lower
> than treshold. All that functionality can be attempted with  few
> existing grass commands (r.to.vect, v.db.addcolumn, v.to.db v.to.rast,
> r.mapcalc sequentially) but I spend less time programing this module
> than performing this set of operation (on rather huge map with over
> 100000 cluped areas)
> r.convergence
> specializing module reworked from SAGA. Calculate convergnece index for
> given area based on DEM. Good wor detecting geomorphological lineaments.
> It use different method for slope-aspect calculation than SAGA (but the
> same as in GRASS r.slope.aspect), also can work in lat-long projections.
> As always any comments, tests, suggestions and critics are welcome
> Jarek
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dear Jarek,
I am trying to use r.area, but with no success.
I have a raster ("my_raster") that contains either the value 255 or 0. So
first I used r.clump to create unique categories:
r.clump input=my_raster output=my_raster_clumped
And then I used r.area like this:
r.area input=my_raster_clumped output=my_raster_area
But then I get the following error:
ATENÇÃO: Raster map <my_raster_clumped> not found in mapset
           <my_raster_clumped>
ERRO:<my_raster_clumped> is not of type CELL, probably not crated with
     r.clump
The result of r.info for the clumped raster is:
 | Layer:    my_raster_clumped              Date: Sat Jun 19 20:23:45 2010
 | Mapset:   ATLANTIC                       Login of Creator: marcello
 | DataBase: /home/marcello/grassdata
 | Title:    clump of <my_raster at ATLANTIC> ( my_raster_clumped )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 26
 |   Data Type:    CELL
 |   Rows:         296
 |   Columns:      326
 |   Total Cells:  96496
 |        Projection: Mercator
 |            N:    3948000    S:    3652000   Res:  1000
 |            E:   -7037000    W:   -7363000   Res:  1000
 |   Range of data:    min = 1  max = 26
 |   Data Description:
 |    generated by r.clump
The usage is so simple and the error is so nonsense that I have no clues of
what may be happening. Any ideas?
Best regards,
Marcello.
P.S.: By the way, thank you for the fuzzy modules. They made my life much
easier.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/New-modules-in-svn-add-on-r-area-and-r-convergence-tp5161926p5199839.html
Sent from the Grass - Users mailing list archive at Nabble.com.
