[GRASS-user] Grass e QGIS on netbook with ubuntu 10.4 remix
Maris Nartiss
maris.gis at gmail.com
Tue Jun 22 02:15:22 EDT 2010
Hello,
if You use GRASS from within QGIS, You should contact QGIS developers,
as GRASS support in QGIS is developed by QGIS developers and not
GRASS'ers.
I have not used Ubuntu, still in KDE with KWin I can drag around
windows by holding Alt key. Probably helps.
Maris.
2010/6/21, Edmondo Elisei <edmondo.elisei at gmail.com>:
> I'm using qgis 1.4 as plugin in GRASS 6.4 on a eeepc 1008 netbook with
> ubuntu 10.4 REMIX.
> The properties-layer panel aren't resizable and i'm not able to view the
> bottom command (as the "Ok" botton).
> I've tried change the monitor resolution with the same result.
> Some suggestion?
> thanks and regards (... I'm sorry for my english)
> E.
