[GRASS-user] bash script
Sandile Gumede
akasandile at gmail.com
Thu Jun 24 04:02:08 EDT 2010
I'm using ubuntu, I installed grass from the synaptic. So the script to
start grass is in /usr/bin then the file name is grass64 (/usr/bin/grass64)
and the scripts are in /usr/lib/grass64 then inside grass64 folder you get
other folder like scripts and so on. That is why in my script I wrote:
# start GRASS
GISBASE=/usr/bin/grass64
# path to the scripts
GISBASELIB=/usr/lib/grass64
But I tried to export the PATH you gave me, still giving me an error of
r.in.gdal not found
On Thu, Jun 24, 2010 at 9:16 AM, Markus Metz <
markus.metz.giswork at googlemail.com> wrote:
> Sandile Gumede wrote:
> > [snip]
> > # first our GRASS, then the rest
> > export PATH=$GISBASE:$GISBASELIB/scripts:$PATH
> Try
> export PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
> See also etc/init.sh for inspiration
> Markus M
Kind Regards
TS Gumede
CSIR, Meraka Institute
072 258 1650
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100624/6cc897bd/attachment.html
