[GRASS-user] SQLite connection - error
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Thu Jun 24 04:48:36 EDT 2010
You could try compiling GDAL with GRASS support and
using ogr2ogr directly to convert from the external
format to GRASS.
Ben
----- Original Message -----
> Thanks Achim and Ben for your quick answers! I never even thought
> about that(a bit embarrassing really :-) )
> I suppose that means I am back to the horribly slow import through
> v.in.ogr. Practically impossible for me to import a 100 mb shapefile.
> If anybody has suggestions for good performance, please go ahead and
> tell me.
> Espen
> 2010/6/24 Achim Kisseler <achim.kisseler at jupiter.uni-freiburg.de>:
> > This is because SQLite is not SpatiaLite (SQLite with spatial
> > extension).
> > GRASS does not support SpatiaLite as far as I know.
> > If you just want to use the Data from Spatiallite, you can export
> > the tables
> > as shape-files or csv and import these to GRASS.
> > Hope it helps a bit,
> > Achim
> > Espen Isaksen schrieb:
> >> Hi!
> >> I have tried to read the documentation and the mailing list for how
> >> to
> >> connect to a SQLite database. So far I have done this:
> >> 1. db.connect driver=sqlite database='/home/espen/db.sqlite'
> >> 2. Created a new vector map called test
> >> 3. v.db.connect map=test table=GSHHS_f_L2 -o key=PK_UID
> >> However I get this warning:
> >> WARNING: SQLite driver: unable to parse decltype: POLYGON
> >> WARNING: SQLite driver: column 'Geometry', SQLite type 2 is not
> >> supported
> >> supported The table <GSHHS_f_L2> is now part of vector map <test>
> >> and may be deleted
> >> or overwritten by GRASS modules
> >> And running v.info map=test show that the layer does not have any
> >> objects
> >> | Layer: test
> >> | Mapset: PERMANENT
> >> | Location: newLocation
> >> | Database: /home/espen/Dokumenter/grassdata
> >> | Title:
> >> | Map scale: 1:1
> >> | Map format: native
> >> | Name of creator: espen
> >> | Organization:
> >> | Source date: Wed Jun 23 08:55:30 2010
> >> | Type of Map: vector (level: 2)
> >> | Number of points: 0 Number of areas: 0
> >> | Number of lines: 0 Number of islands: 0
> >> | Number of boundaries: 0 Number of faces: 0
> >> | Number of centroids: 0 Number of kernels: 0
> >> | Map is 3D: No
> >> | Number of dblinks: 1
> >> | Projection: Lat/Lon
> >> | N: 0 S: 0
> >> | E: 0 W: 0
> >> | Digitization threshold: 0
> >> | Comments:
> >> Could anybody explain to me what the warning means, and why I
> >> cannot access the features? The only thing i can guess is that I
> >> can only use
> >> version 1 of SQLite? However, I am not familiar with the different
> >> versions of SQLite.
> >> Kind regards,
> >> Espen Isaksen
> >> _______________________________________________ grass-user mailing
> >> list grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
