[GRASS-user] Changing menudata.xml to include an direct
processing
Franz Schiller
franzschiller1975 at gmail.com
Mon Jun 28 05:14:27 EDT 2010
Hi
Martin, it's not possible in GRASS6.4.0RC6. It still opens the module-panel
and parameterizes it. has anyone ever tried to have a module that runs, from
the menu, without opening module-panel?
Thanks
Best regards,
Franz
On Fri, Jun 18, 2010 at 1:35 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2010/6/9 Franz Schiller <franzschiller1975 at gmail.com>:
> > Greetings
> > I'm making some addaptions in menudata.xml in order to have a few
> functions
> > available more rapidly (for me). I wanted to have a menu-item (I know how
> to
> > add it) that runs directly without opening any panel. This would mean
> that
> > all parameterization would be in the xml. Is this possible?
> yes, it's possible in 6.5+. In 6.4 it will be probably not working.
> <menuitem>
> <label>Info elevation map</label>
> <help>Show menudata of elevation raster map</help>
> <handler>OnMenuCmd</handler>
> <command>r.info map=elevation</command>
> </menuitem>
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100628/a5fef1f4/attachment.html
