[GRASS-user] Datum not recognized by GRASS
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Jun 30 02:39:14 EDT 2010
On Wed, 30 Jun 2010, Anders Gonçalves da Silva wrote:
> Hello all. I am trying to add a GeoTIFF to a project, but I keep getting the following message:
> GRASS 6.4.0RC6 (pontal):~/Documents/Academic/Thesis/Archive/Sampling > gdalinfo pontal.TIF
> Driver: GTiff/GeoTIFF
> Files: pontal.TIF
> Size is 4337, 2727
> Coordinate System is:
> PROJCS["UTM Zone 23S",
> GEOGCS["South_American_1969",
> DATUM["South_American_1969",
This seems to be non-standard; the EPSG name should be
South_American_Datum_1969 and then GRASS would pick it up correctly.
Perhaps we need to add an exception in lib/proj/convert.c; unfortunately
I'm just about to head away for a few days and don't have time right now.
Paul
> SPHEROID["South American 1969",6378160,298.2500000654724]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-45],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",10000000],
> UNIT["unknown",1]]
> Origin = (280686.235600000014529,7573063.005800000391901)
> Pixel Size = (30.000000000000000,-30.000000000000000)
> Metadata:
> TIFFTAG_SOFTWARE=ERDAS IMAGINE
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 280686.236, 7573063.006) ( 47d 7'24.05"W, 21d55'58.77"S)
> Lower Left ( 280686.236, 7491253.006) ( 47d 8'4.36"W, 22d40'17.64"S)
> Upper Right ( 410796.236, 7573063.006) ( 45d51'49.82"W, 21d56'39.98"S)
> Lower Right ( 410796.236, 7491253.006) ( 45d52'6.24"W, 22d41'0.39"S)
> Center ( 345741.236, 7532158.006) ( 46d29'51.35"W, 22d18'33.65"S)
> Band 1 Block=4337x5 Type=Byte, ColorInterp=Red
> Band 2 Block=4337x5 Type=Byte, ColorInterp=Green
> Band 3 Block=4337x5 Type=Byte, ColorInterp=Blue
> I have tried to use gdalwarp to reset it to something that GRASS can read. While I get it to run, the projections are not lining up. In particular, it seems to be off by a few degrees to the East. Any help in fixing this would be greatly appreciated. Thank you.
> Anders._______________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
