[GRASS-user] v.out.ogr issue
daniel mcinerney
daniel.o.mcinerney at gmail.com
Wed Jun 30 07:35:43 EDT 2010
Hi List,
I'm having trouble exporting a GRASS vector file
using v.out.ogr. The file contains 1 million
areas and its attributes are stored in a
postgresql table (view of joined tables and
connected to geometry using v.db.connect).
When I run the following command:
v.out.ogr -c type=area input=g1km dsn=/tmp/shp
I get the following error:
99%
dbmi: Out of Memory
ERROR: Cannot select attributes for cat = 991956
I can successfully create the shp file using the
above procedure for a small vector file containing
400 areas, but I'm wondering if it's possible to export
the large dataset?
I'm running GRASS 6.5.svn on Linux and have compiled it
with --enable-largefile.
Thanks in advance,
Daniel.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100630/e0ac2e1f/attachment.html
