[GRASS-user] Trouble running Grass 7
Ned Horning horning at amnh.org
Wed Jun 30 17:47:01 EDT 2010
Hi Markus,
Thanks for the reply. He are the results of the two commands you requested:
nedhorning at ubuntu-desktop:~$ uname -a
Linux ubuntu-desktop 2.6.32-22-generic #36-Ubuntu SMP Thu Jun 3 19:31:57
UTC 2010 x86_64 GNU/Linux
nedhorning at ubuntu-desktop:~$ ldd /usr/lib/libproj.so.0.6.6
     linux-vdso.so.1 =>  (0x00007fff66bff000)
     libm.so.6 => /lib/libm.so.6 (0x00007f3cda7b2000)
     libc.so.6 => /lib/libc.so.6 (0x00007f3cda430000)
     /lib64/ld-linux-x86-64.so.2 (0x00007f3cdac9a000)
Ned
On 06/30/2010 05:27 PM, Markus Neteler wrote:
> Hi Ned,
> On Tue, Jun 29, 2010 at 2:09 PM, Ned Horning<horning at amnh.org>  wrote:
>> Hi - I am trying to install Grass 7 in a local directory and the installation seems to have gone ok but when I run it I get the following error:
>> WARNING: Nviz extension (3D view mode) disabled. Reason: /home/nedhorning/bin/grass70/lib/libgrass_datetime.7.0.svn.so: wrong ELF class: ELFCLASS32
> Please post
> uname -a
> I suspect that 64bit and 32bit libraries are mixed.
>> I'm not too concerned about the Nvis error but the problem with libgdal.so.1 is preventing GRASS from starting. I have a file /usr/lib/libproj.so.1 which is a link to the shared library /usr/lib/libproj.so.0.6.6. Is this a version problem?
> Please post
> too.
>> I have GRASS 6.4 ORC6 running just fine.
> Markus
