[GRASS-user] Trouble running Grass 7
Ned Horning
horning at amnh.org
Wed Jun 30 21:40:11 EDT 2010
Markus,
Thanks for the diagnostic help. I was using the GRASS 7 binary so that's
the problem. I'll try to compile GRASS 7 using the SVN snapshot to see I
can get that to work.
Thanks for your patience.
Ned
On 06/30/2010 06:18 PM, Markus Neteler wrote:
> On Wed, Jun 30, 2010 at 11:47 PM, Ned Horning<horning at amnh.org> wrote:
>> Hi Markus,
>> Thanks for the reply. He are the results of the two commands you requested:
>> nedhorning at ubuntu-desktop:~$ uname -a
>> Linux ubuntu-desktop 2.6.32-22-generic #36-Ubuntu SMP Thu Jun 3 19:31:57 UTC
>> 2010 x86_64 GNU/Linux
> -> 64 bit box!
> as suspected, you have also 32bit files around:
> On Tue, Jun 29, 2010 at 2:09 PM, Ned Horning<horning at amnh.org> wrote:
>> WARNING: Nviz extension (3D view mode) disabled. Reason:
>> /home/nedhorning/bin/grass70/lib/libgrass_datetime.7.0.svn.so: wrong ELF
>> class: ELFCLASS32
> That's incompliant... Did you self-compile all on *that* machine?
> If yes, a "make distclean" and recompilation should solve the problem.
> Markus
