[GRASS-user] POW() in SQLite?
Hamish
hamish_b at yahoo.com
Mon Mar 1 00:55:47 EST 2010
I am trying to use POW(x,n) with SQLite but it fails:
G65> v.db.select mapname column="POW(length,3)"
DBMI-SQLite driver error:
Error in sqlite3_prepare():SELECT POW(length,3) FROM mapname
no such function: POW
ERROR: Unable to open select cursor
Similar problem if I try x^n:
unrecognized token: "^"
What I really want to do is add that value as a new column:
G65> v.db.update mapname column=volume value="POW(length,3)" --verbose
but I get the same error. It doesn't work with DBF either, but I sort
of expected that.
this random webhit suggests that it should be possible:
http://osdir.com/ml/sqlite-users/2009-03/msg00248.html
any ideas?
not a DB guru,
Hamish
