[GRASS-user] r.param.scale Question
    Rich Shepard
    rshepard at appl-ecosys.com
    Mon Mar  1 16:18:40 EST 2010
On Mon, 1 Mar 2010, Patton, Eric wrote:
> It's possible there are outliers in your raster map that are skewing the
> color table; what is the result of r.info -r? Check to see the range of
> the raster makes sense.
Eric,
   That's not the situation here: no outliers. I successfully ran this at 5
and 10m resolutions, and once at 25m resolution. The region was incorrect in
this last case and after properly setting the region I could no longer
produce the multicolored map I did before.
   I'm not using that map since I _must_ get this report done and found a
different module (r.resamp.rst) that also generates tangential curves.
Thanks,
Rich
