[GRASS-user] problem with spgrass6
Hamish hamish_b at yahoo.com
Mon Mar 1 21:56:57 EST 2010
> Leo Hardtke wrote:
> > I am using spgrass6 in a grass6.4-R2.9.2 on Ubuntu 9.10 without problems
> > //x=readRAST6(c("raster.a","raster.b"))/
> > but when i run the same line in grass65svn it gives an
> error with some rasters(DCELL)... (and other  are
> imported without problems(DCELL too))
> > /CPL ERROR 4:
> `/media/COMP/grassdb//hardtke/Bisigato/.tmp/rs7/ndvi_sum'
> does not exist in the file system,
> > and is not recognised as a supported dataset name.
the "//" in the middle of the path makes me suspect that there is a
$VARIABLE there which is supposed to be set but is empty for some reason.
(does that file exist?)
Hamish
