[GRASS-user] Export/define region with Map Scale
Franz Schiller franzschiller1975 at gmail.com
Tue Mar 2 04:53:13 EST 2010
Greetings Hamish
> yes. the ps.map module knows its output plots will be on paper,
> and it knows how big that piece of paper is. therefore it can
> correctly calculate and use the scale for PostScript (and so
> PDF format too) hardcopies.
Ok. So I just need to define the scale-output . Seems reasonably and easy :)
> > 2- Is it possible to set region using this map scale
> > definition in order to have by default this setting?
> not directly, but you could write a script wrapping g.region
> and d.info which after calibration could keep you somewhat
> close to your desired scale. That's probably more trouble than
> it's worth though.
yes. It seems to. It seems easier to define Scale only in the output
Thanks
Franz
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/6ebb4fa1/attachment.html
