[GRASS-user] Re: [r.resample] null values for min and max range of data values
baobazz baobazz at hotmail.fr
Tue Mar 2 06:44:14 EST 2010
Thanks for your answer!
I didn't launch r.in.gdal after r.resample. It's just part of the raster
history info given by the r.info command.
Here is the complete workflow without the info commands. The goal is to
produce an image with a less precise resolution.
1)r.in.gdal input=C:/tests/GRASS/rasterToVect/BDP_08_1234_6134_010_L93.tif
output=raster6133_2
2)g.region res=2
3)r.resample input=raster6133_2 output=raster.resampled
-raster6133_2 with no null range of values
-raster.resampled with null range of values (:-(()
If you see why there are null range of values..
Thanks!
View this message in context: http://n2.nabble.com/r-resample-null-values-for-min-and-max-range-of-data-values-tp4631171p4660500.html
Sent from the Grass - Users mailing list archive at Nabble.com.
