[GRASS-user] R-GDAL incompatible libraries
Leo Hardtke
leohardtke at gmail.com
Tue Mar 2 09:51:37 EST 2010
Hi Kim
I am using R 9.2 (ubuntu repo),
grass6.5 (source), and grass6.4(ubuntugis) works too,
rgdal (source, not the lates
thttp://cran.r-project.org/src/contrib/Archive/rgdal/rgdal_0.6-21.tar.gz
), and
spgrass6 (install.packages("spgras6") in R)
Hope it works
Leo Hardtke
Kim Besson escribió:
> Ok I have just installed latest GRASS snapshot and I got the following
> error
> > precip30n <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
> ERROR: Incompatible library version for module. You need to rebuild GRASS
> or untangle multiple installations.
> What I would like to know is the versions of R and spgrass6 that I
> should install on my system in order to not get this errors?
> Thanks
> Kim
> 2010/3/2 Kim Besson <kimbesson1981 en gmail.com
> <mailto:kimbesson1981 en gmail.com>>
> Hi
> I have installed R from Ubuntu repositories. My grass installation
> is a Weekly snapshot.
> I had to install rgdal since it doesn't exist in UBUNTU
> repositories neither CRAN and the same with spgrass6.
> Ok I will rebuild grass and reply again to mailing list
> Thanks
> Kim
> Did you install grass from source? Did you install R, spgrass6 from
> source?
> - If you have installed grass from source, then try to rebuild
> grass
> (after having installed R and the rest).
> - If you have grass from the ubuntu repositories, the you should
> probably stick with R and the rest from the repositories as
> well. If the
> latter is the case and it does not work, then there is a problem.
> Tell us a bit more...
> Nikos
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
