[GRASS-user] R-GDAL incompatible libraries
Kim Besson
kimbesson1981 at gmail.com
Tue Mar 2 10:15:16 EST 2010
Ok I reinstalled rgdal
R CMD INSTALL rgdal
And then:
R
library(spgrass6)
Output:
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.5.4, released 2009/01/07
Path to GDAL shared files: /usr/share/gdal15
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.4.0svn
and location: North-Carolina
precip30 <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
Same error.
I'm running GRASSsvn6.4.0, from latest week, in a Linux Machine with:
rgdal_0.6-10
spgrass6_0.6-15.
R version 2.9.2 (2009-08-24)
Any idea of what might not be compatible?
Thank you
Kim
2010/3/2 Markus Neteler <neteler at osgeo.org>
> 2010/3/2 Kim Besson <kimbesson1981 at gmail.com>:
> > Ok I have just installed latest GRASS snapshot and I got the following
> error
> >> precip30n <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
> > What I would like to know is the versions of R and spgrass6 that I should
> > install on my system in order to not get this errors?
> You also need to update the GRASS-GDAL plugin.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/505e0067/attachment.html
