[GRASS-user] Fuzzy logic in GRASS
    Jarosław Jasiewicz
    jarekj at amu.edu.pl
    Wed Mar  3 03:44:30 EST 2010
Hi list
I added to SVN-ADD-ON repository two new modules:
r.fuzzy: calculates membership of image according mempership function
definied by user with 4 inflection poin and some addationa parameters
(see description)
r.fuzzy.logic perform fuzzy logic operations (OR, AND, NOT and
implication) with 6 families of T-norm and complement dual T-conorms
That modules are only sketch of something bigger which I plan to evolve
into full fuzzy logic system (with rules, inferance and decision support
system)
There are at least however on problem:
r.fuzzy for GRASS exist and not exist (by Francois Delclaux). I tried to
contact with author but it failed and  module is not available from
add-on web page. For now I leave name r.fuzzy, but if it could be the
problem I can change name or remove both module.
I need some comments about my work:
- for r.fuzzy shape parameter use nonstandard solution which is not
applied in any software known for me. What you think about it? Or shall
I change it into standard dilatation/concentration parameter (power/sqrt)
- i plan to add custom fuzzy set definition but it require manual typing
of sets of points or some more complex membership function definition
which may be difficult without visual assistance, so I'd like to know if
it would be really useful
modules are very simple, but If there would be some problems with
compilation or working, please let me know
ragards
Jarek Jasiewicz
