[GRASS-user] How to embed a grass script (for example v.db.addcol)
into a Pythonscript on windows?
Glynn Clements
glynn at gclements.plus.com
Thu Mar 4 16:23:53 EST 2010
Sonja Jankowfsky wrote:
> I deleted all reference to the to the scripts directory in the PATH, but
> I still have the same problem:
> '""' n'est pas reconnu en tant que commande interne ou externe, un
> programme ex�cutable ou un fichier de commandes.
I think it's saying:
'""' is not recognized as an internal or external command,
operable program or batch file.
That suggests that GRASS_SH isn't set. The batch files used to invoke
scripts all contain a command of the form:
@"%GRASS_SH%" -c '"%GISBASE%/scripts/v.db.addcol" %*'
If GRASS_SH isn't set, that becomes:
@"" -c '"%GISBASE%/scripts/v.db.addcol" %*'
When starting GRASS via the grass64.bat file, GRASS_SH should end up
being set to "c:\msys\1.0\bin\sh.exe". I believe that the installers
override this setting to use a copy which is installed in the GRASS
directory.
