[GRASS-user] grass shell
    maven apache
    apachemaven0 at gmail.com
    Fri Mar  5 01:18:22 EST 2010
2010/3/5 Glynn Clements <glynn at gclements.plus.com>
> maven apache wrote:
> > Hi, thanks for your detailed reply.
> > And I have write a java class according to your instruction,however it
> can
> > not give the right output.
> What output does it give?
> > I test with the spearfish60 data and the
> > r.infoprocess.
> > Attach my code, can you check it ?
> >       public String run(String cmd)    {
> >               try {
> >                       cmd="/bin/sh -c " + cmd;
> >                       String[] exe={"/bin/sh -c",cmd};
> >                       Process p1=rt.exec(exe,env);
> I suggest that you don't use the shell; it just makes life harder.
> Instead, define:
>        public String run(String[] cmd)  {
>                        Process p1=rt.exec(cmd, env);
> and use:
>        gm.run({"r.info", "map=roads"});
Hi, I use the following:
    String[] exe = { "bash", "-c", cmd };
    Process p1=rt.exec(exe, env);
Now it works, thank you anyway! I can not make it work without your patient
explanation these days! Your are a good guy!
Also, I want to say "Thank you" to everyone who have help me complete my
job.! :)
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100305/49af09a1/attachment.html
