[GRASS-user] ps.map legend with rgbcolumn colors
Hamish
hamish_b at yahoo.com
Fri Mar 5 04:05:32 EST 2010
Luigi:
> I am impressed with ps.map results (never used before): it
> does look a lot more like a printed map.
that's the idea! :)
> > where column_name = 'zonename'
> On my system it needs to be unquoted (at least in my case,
> where values were integers) -- I mean, no quotes at all.
right, 'quotes' are for when you are matching strings
> https://docs.google.com/fileview?id=0B0EpsfMZ-IZYYmYwYmRlMWItY2Y4NS00MTNhLWEzZWUtZjQ2Y2U0OTU2YzRi&hl=it
very good!
> One thing I am not able to do yet, is to use system fonts (e.g. Arial).
> I have tried by setting absolute path but it doesn't seem to work. I am
> afraid this is more of a postscript question... Is ps.map able to
> access and embed GRASS fonts? (ok, tried to get GRASS in.)
from the ps.map help page: (near the top)
font font name
The name of the PostScript font. Fonts present in
all PostScript implementations are: Times-Roman,
Times-Italic, Times-Bold, Times-BoldItalic, Hel-
vetica, Helvetica-Oblique, Helvetica-Bold, Hel-
vetica-BoldOblique, Courier, Courier-Oblique,
Courier-Bold, and Courier-BoldOblique.
The default is Helvetica.
PostScript needs to use a font known to PostScript printers, not TTF
fonts known to the system. Maybe there is a way around that but I don't
know it. Note the above list is the minimum set, there may well be more
available locally.
Hamish
