[GRASS-user] How to embed a grass script (for example v.db.addcol)
	into a Pythonscript on windows?
    Sonja Jankowfsky
    sonja.jankowfsky at cemagref.fr
    Fri Mar  5 11:01:07 EST 2010
For Eclipse it's working fine now. I updated the wiki with the correct
environment variables:
http://grass.osgeo.org/wiki/Using_Eclipse_to_develop_GRASS_Python_programs
Sonja Jankowfsky a écrit :
> I added C:\GRASS-4-SVN\msys\bin to my PATH, and now I only have the
> problem with the SSLEAY32.dll.
>> Many thanks for your tips!
>> Concerning the missing ordinal, I had a check and I only have 2
>> SSLEAY32.dll libraries on my machine:
>> The one in C:\GRASS-4-SVN\extralib, which is indicated in the PATH
>> and one other in  C:\OSGeo4w\bin, but that's not in the PATH. So
>> windows should take the first one.
>> I think, the problem with the ordinal is coming from something else,
>> but I don't know what.
>> Concerning the second problem I added GRASS_SH =
>> C:\GRASS-4-SVN\msys\bin\sh.exe (I only have msys inside GRASS
>> installed) to the environment variables.
>> Now, I get a different error message:
>> C:\GRASS-4-SVN/scripts/v.db.addcol: line 55: basename: command not found
>> C:\GRASS-4-SVN/scripts/v.db.addcol: line 63: basename: command not found
>> C:\GRASS-4-SVN/scripts/v.db.addcol: line 66: which: command not found
>> ERREUR :awk required, please install awk or gawk first
>> do I have to add other executable to the environment variables?
>> Glynn Clements a écrit :
>>> Sonja Jankowfsky wrote:
>>>> in C:\Windows\system32\cmd.exe
>>>> C:\GRASS-4-SVN\bin\v.in.ogr.exe
>>>> result: L'ordinal 284 est introuvable dans la bibliothèque de
>>>> liaisons dynamique SSLEAY32.dll.
>>> I think that's something like "the ordinal 284 could not be found in
>>> the dynamic library SSLEAY32.dll". SSLeay is the original name of
>>> OpenSSL, which is used by some of the libraries used by GDAL
>>> (typically database libraries).
>>>> (call to v.in.ogr works fine in a pythonscript run in Eclipse, but
>>>> not run in the windows command line)
>>> A missing ordinal suggests that it's finding the wrong version of the
>>> library. This is likely to be related to the PATH setting, which
>>> Windows uses to locate DLLs, as well as executables.
Sonja Jankowfsky
UR Hydrologie-Hydraulique
Cemagref de Lyon
3 bis quai Chauveau CP 220
69336 Lyon Cedex 09
FRANCE
Tel : (+33)4 72 20 86 11
Fax : (+33)4 78 47 78 75
