[GRASS-user] Why does v.split convert 3D vector to 2D?
Dwight Needels
needels at translucida.com
Sun Mar 7 13:13:52 EST 2010
I have a 3D vector [test_3D] created using v.drape, confirmed as 3D
with v.info. I used v.split to split the polyline at the vertices:
v.split input=test_3D output=test_3D_split vertices=2
The resulting vector [test_3D_split] is a 2D vector (i.e. it lost the
z geometry data according to v.info, and v.to.db reports all slopes =
0).
Is this intended behavior?
Thanks, -Dwight
