[GRASS-user] Why does v.split convert 3D vector to 2D?
Martin Landa
landa.martin at gmail.com
Sun Mar 7 15:10:02 EST 2010
2010/3/7 Markus Neteler <neteler at osgeo.org>:
> cd v.split/
> grep open * | grep new
> main.c: Vect_open_new(&Out, out_opt->answer, 0);
>> Is this intended behavior?
> Certainly not ideal. I don't know if changing to
> Vect_open_new(&Out, out_opt->answer, WITH_Z);
> would be sufficient (of course recompile after that). If you could
> provide a test case with the Spearfish or North Carolina test
> datasets, I could try if you aren't able to compile GRASS yourself
> to test above suggestion.
should be fixed in r41335 (synchronized with trunk). Please test it. Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
