[GRASS-user] can I access mapset outside of grass, by using
python?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Mar 7 22:19:28 EST 2010
Apologies for a second post with the code. Just to make it easier to
read/ understand what I've changed.
Νίκος Αλεξανδρής wrote:
> > Is there a way to lock-out all other versions of grass-modules from
> > being detectable when I am already inside a grass70 session?
Glynn Clements wrote:
> The grassXY scripts prepend the GRASS directories to PATH,
> LD_LIBRARY_PATH, etc. They won't remove any entries which are already
> there.
> I only use the grassXY scripts if I actually need to test the startup
> process. To switch versions, I use the following script:
> strippath()
> oldpath="$1"
> newpath=
> IFS=:
> for dir in $oldpath ; do
> case "${dir}" in
> *grass*)
> newpath="$newpath:$dir"
> esac
> done
> echo "${newpath#:}"
> PATH=`strippath $PATH`
> export GISBASE=$PWD/dist.i686-pc-linux-gnu
> export PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
> export LD_LIBRARY_PATH="$GISBASE/lib"
> export PYTHONPATH="$GISBASE/etc/python"
> Note: the above script needs to be "source"d; executing it won't work.
-- slightly modified code --
strippath()
oldpath="$1"
newpath=
IFS=:
case "${dir}" in
*grass*)
esac
done
echo "${newpath#:}"
unset IFS
export PATH="$GISBASE/bin:$GISBASE/scripts:`strippath $PATH`"
-- end of slightly modified code --
Nikos
