[GRASS-user] Calculating Length Between Points On Stream Network
Rich Shepard
rshepard at appl-ecosys.com
Mon Mar 8 08:54:19 EST 2010
On Mon, 8 Mar 2010, Wolf Bergenheim wrote:
> The 'id' should not be the string 'id', but rather a unique IDentifier
> for each point. Usually you will want to use a running number, so that
> the first is 1 the second is 2 etc...
> Here is an example of 2 lines:
> 1 242856.60 431305.07 242551.88 432149.70
> 2 242866.60 431325.07 242550.88 432140.70
Wolf,
Thank you. That was not clear from the man page.
Much appreciated,
Rich
