[GRASS-user] r.cost - extra output needed
"António M. Rodrigues"
amrodrigues at fcsh.unl.pt
Tue Mar 9 11:36:54 EST 2010
Dear users,
I'm using r.cost to calculate time distances based on friction
calculated using a road network and some other information.
From what I understant, r.cost only outputs "accessbility" surfaces.
The problem is I also need the identity of the nearest target
(catchment areas or allocation surfaces or some other way you whish to
call it).
How could I achieve this?
Thanks in advance.
António
