[GRASS-user] Re: Importing Raster- Newbie
Markus Neteler
neteler at osgeo.org
Wed Mar 10 17:37:25 EST 2010
On Wed, Mar 10, 2010 at 11:10 PM, Franz Okyere <franzzoa77 at yahoo.co.uk> wrote:
> So here is the attached report from gdalinfo. Hope you can offer some help from here. Cheers.
OK - it looks to be "nicely" messed up by multispec:
Coordinate System is:
PROJCS["Generated by MultiSpecWin32_12.20.2007 on 03-09-2010 18:02:00",
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (567976.937500000000000,787046.062500000000000)
Pixel Size = (15.000000000000000,-15.000000000000000)
Corner Coordinates:
Upper Left ( 567976.938, 787046.063)
Lower Left ( 567976.938, 775256.063)
Should this be UTM coordinates? Where is the place approximately?
Once figured out, you can assign the correct metadata with the
gdal_translate tool.
Markus
